Results 1 to 7 of 7
Thread: front and rear swaybars on a mk1 golf
    Nov 2007
    hi all
    Im new to the forum and was wondering, if i put a front and rear swaybar on a mk1 golf will it pick up either of the rear wheels when i go around a corner? because i heard that it will pick up the out side rear wheel when i go round a corner.
    thanks in advance
    Tim
    Oakleigh VIC
    Depends on a lot of things like tyres, how fast you're going, the camber of the road etc etc, but yes it is possible.
    Pete
    Aug 2006
    Melbourne VIC
    Mate u can pick up the inside rear wheel if the its nice n stiff... Also yes u can corner real hard and pick up the outside wheel...
    28mm rear bar but u also gota have suspension to suit...
    Dad on picking up the inside wheel coming into Dandenong Rd (Sandown)
    Nov 2007
    well i have a 25mm front swaybar but i was thinking of buying a whiteline swaybar for the rear. i also have adjustable konis all round so i dont if that would make any difference.
    Aug 2006
    Melbourne VIC
    Yeah no probs... Get a 28mm one on the rear... Nuespeed, autotech, whiteline etc are all good...
    Nov 2007
    thanks
    thanks for your help guys and i shall get a bar for the rear
    Perth. WA
    bars..
    Use to pick up the inside rear on my rocco ( A1 chassis) with factory GTI sway bars when doing track play years ago.. all without much effort.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
