![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
sambb
No not all. If the inner pivot is higher than the outer, that will push your roll centre up higher towards the centre of gravity and make it handle better. That's the whole point of roll centre correction kits etc its so that you can run the car low without adversely affecting geometry. The control arms level idea is so that if you don't have roll centre correction, its considered the limit you would take the pivots too without mangling geometry/handling. Thetheoretical point taken for centre of gravity is about crank height normally. Even with your control arms slightly angled up towards the inner you wouldn't get near that I don't think, but the closer the better. Basically my car went from stock height, to H&R fronts which were way too low and had the outer pivots much higher than the inners, raised again with weitecs which put the arms just about level, back to stock after that. Considering that all those springs had identical spring rates to factory, the only thing I was changing was geometry and the H&R's were appalling (way too low), the weitecs were much better (control arms level but still slightly up on the hub end) and stock were the best (level). I now have changed over to 400lb fronts MCA coilovers and I think I'm even a tad higher than stock and it is a proper change for the better, so control arms angling up towards the inner pivots has been nothing but an improvement for me and it aligns the steering arms for less bump steer to boot.
Re the race car using the pre recall control arms I don't know what the difference is between them. Do the ball joint positions create more caster or give wider track. I'd guess that they'd use the ones that give better angles. For front anti roll bar it comes down to how much rear anti roll you'll have. eg if you put the 20mm on and cant get stiff enough rear springs and/or bar into it then it'll want to understeer more, so the front bar choice is a bit more holistic looking at what the whole picture will be. But then again 19mm vs 20mm isn't a huge jump so you cant go badly wrong either way. Are both bars droplinked onto the control arm or does one of them droplink off the strut as off the control arm would be the pick.
