Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: fk coilovers
    Jan 2012
    Bentleigh East, Melbourne, Vic
    fk coilovers
    hi,
    has anybody had some experiance with fk coilovers...for a polo 9n gti
    i have notied that they are very well priced, and if you go for the silverline kit, it has stainless steel body and springs...so should be good and strong and corrosive free.
    Oct 2009
    Canberra ACT
    Hi mate I'm running FK AK street coilies on my 9N3 with no problems at all. Got them from the UK $430 landed
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    Im running FK highsports and they are great!
    Buller Scott on here has Konigsports on his car too, so between us all you've got the entire range (bar silverlines) covered
    Jan 2012
    any comments on the sports ediion plus, whic apparently hs damping (6 settings). Is it wortwhile, what are the major advantages..thnks
    Sep 2006
    Quote Originally Posted by clicht View Post
    I would only go for dampening adjustable if you plan on doing lots of trackwork.
    I had Kw V2's on my VR6 and left them on the softest setting and never changed it
    MODS- TOO MANY
    Sep 2008
    FK's are cheap to buy but remember, you get what you pay for. And no I'm not trying to start a coillies brand war here in case anyone is wondering about my comment. Just remember, if anything goes wrong, you need to either fork out $$$ to get them replaced and $$$ for uninstall and reinstall plus cost of wheel alignment (unless you have a mate who is happy to help out or you can do it yourself). If you're that unfortunate, then you may as well have forked out for a better set in the first place. Don't get me wrong, I too was considering them when looking for coillies but decided in the end for a set of kw v1's. Myself and another forum member here has spoken to retailers of FK's and locally or overseas, even they start umming and arring about it and would recommend another brand like KW unless budget constraints is the limiting factor hence my final decision to go with a reputable brand with an established motorsport involvement to back it up. Just my 2 cents worth.
    Quote Originally Posted by Gti Dave View Post
    unless you ACTUALLY have any written evidence that FK's are of a lower overall quality, to the point of failing prematurely just because they cost less, your opinions are invalid. You also surmise that FK's are NOT a reputable brand?
    Its like saying, don't buy a Skoda, they cost less, you get what you pay for, therefore they are a terrible quality car. You can't really say Skoda has had a reputable brand in the past can you now? So therefore is a VW with the same running gear far superior just because you paid more for it? Silly way of thinking really isnt it?
    I rocked around on hot tunings which are THE budget coilover for over 40,000km's (wound all the way down) and they were fine when I took them out, I dont see why or how FK's would or could be any worse quality. Their manufacturing looked bang on to me with all the ones I've installed and I havent had a complaint yet about their quality. You make it sound like FK's will explode the moment you lower the car back on the ground. Again the 5 sets I've installed all looked the goods in terms of manufacturing.
    Why not buy the Konigsports, they have Koni inserts, and Koni's are rebuild able in Australia. The KW V3's have to be sent back to Germany to get rebuilt. I know which one I'd rather. Why fork out a few hundred extra for KW's when FK does the same job with very similar quality at a better price. Just sayin'
    plus FK's come with warranty just like KW do. So where's the problem?
    Learn to choose your words better Dave.
    Oct 2010
    Melbourne, VIC
    Here's some posts where a guy had a problem with the Street Lines and the replacement time was an issue
    http://www.vwwatercooled.org.au/foru...tml#post726160
    http://www.vwwatercooled.org.au/foru...tml#post716877
    The higher models should be better as they use Koni dampers (and I presume they could be serviced locally as well)
    Resident grumpy old fart
    you can't compare FK streetlines to KW V1's! Of course Streetlines are built to a budget, as they are a BUDGET coilover.
    compare Highsports or Silverlines to V1's. Not FK's answer to Hot Tuning.
    Oct 2010
    Melbourne, VIC
    I wasn't comparing the Street Lines to KW V1s - I was just putting your comment about the budget (HotTuning, FK AK/Street Line) in perspective. The OP is talking about Silver Lines which are comparable to the KW V1s in price and quality AND have adjustment.
    And in the other thread on this (in the Polo forum) I made the same point as you about servicing KW dampers.
    Settle down FFS
