Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Expensive OEM wheels
    Feb 2008
    Quote Originally Posted by Bpilot View Post
    Quality own wheels stay true do not flake and are better quality then the cheap Chinese aftermarket foil you buy. OEM or a good quality wheel is the way to go. Remember you get what you pay for
    You have never had to true out an OEM wheel then?? OEM is just an over priced ripoff... You can nearly buy a good set of BBS's for cheaper than OEM fitment in the same size....
    Mar 2011
    Quote Originally Posted by slam View Post
    7.5J x 17, ET51, 57.1mm centre bore
    Where did you get those specs from? The correct specs are 17x7 ET46 57.1mm bore.
