i guess that should answer your questions dude... thanks sean
dom
DOm, that might be BS!
I have a mk3, now I know that's different, but the mk2 and 3 are similar. Infact, the hottunings for a mk3 are also used for a mk2. So, you'd be using the same setup as me.
Now, I am running 16x7 et35 at the moment with HEAPS of space between wheel and spring!!!! So, I'm pretty sure a 40 will fit. If it doesn't, only a small spacer will be required! But I doubt it!
dom
Have to agree with std brakes should still clear. Then again it's wheel width ie 16x8 et40 is 1" closer to the coil than 16x6 et40...
Thanks for the reply guys. Theres about 4cm space there now between shock and tire so i would think it should "just" fit with the coilovers, and if not i will go get some 4 or 5mm spacers. Thanks alot for your help again![]()
----[ Finished the search for a mk2 GTI]----
1990 Golf Mk2 GTI
276* cam
2 1/4 in straight through exhaust
H&R springs on KYB shocks
