bro! you should NOT rush choosing wheels, do PLENTY of re
search on here and
vwvortex.
For an example of a correct fitment, i'm running 17x8 et25 all round on coilovers to what I would say pretty dumped. tire size is critical! if you can stretch (running the smallest or smaller tire than recommended) your tires do it as it will give you more clearance; I'm running 205/40 on the front and 215/40 on the rear. yes I had to roll the guards extensively but the end result is no scrubbing.
It can be done and the only advice I would give to you is
don't listen to most if not all tire shops because they just get out their little Bible from under the desk and read. Work out how to measure offsets and rim widths to choose your own wheels.
