Results 1 to 3 of 3
Thread: Drive shaft rubbing on steering rack!
    May 2012
    Drive shaft rubbing on Swaybar!
    So I put Coilovers in recently and when turning hard would always hear this weird scrubbing noise. Found out tonight my drive shaft is rubbing up against my Swaybar! Is this common and is there a way I can fix this???
    Is it dangerous to drive on?
    I will post pics tomorrow.
    Pretty common.. some of the Mk4 boys will probably pipe up with the specifics but you need shorter drop-links to move the swaybar away from the driveshafts. I just had to do the same on my Polo, little bit different setup, but same principle
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    May 2012
    Thanks mate...ill have to look into something.
    Pic:
