2 cans of Generic primer 450g
2 cans of Acrylic clear 450g
2 cans of Paint 450g
Sand back the wheels with 240-400 sand paper, clean with methylated spirits or equivalent. Let it dry, then spray with the primer doing the back first. Do about three coats, then wait for it to dry completely give it an hour, then use the paint, approximately 3 coats. Then let that dry for at least 3 hours, then spray it with the clear for around 2 coats. Wait for it to dry overnight, hit it in the morning with a decent car polish, enjoy!
REMEMBER less is MORE and PATIENCE is a virtue when it comes to this, don't rush it or you'll either end up with a bad job or be unhappy with it and start over as I did once
As for filler just use generic spot putty, does a perfect job, and give that at least 12 hours before you start sanding it or working on it.
