Made my day haha..
Great writeup and an excellent result RayRay. Out of interest, what sort of silver do you use and how does it compare to a 'stock' wheel colour?
Printable View
I bought a tin of Concept Paints' Wheel Silver from a local auto paint shop. It's a single stage metallic silver (no clearcoat required) and to me, it looked just a touch darker than most OEM wheel silvers.
I've tried Wheel Silver from Septone paints (what you can find @ Supercheap) and their shade was very close to OEM silver. No pictures but I used it to spray the lips on my sister's wheels and they matched the colour of the spokes pretty well (no blending work).
such a useful thread! What do you guys think about getting these wheels: http://www.vwwatercooled.org.au/foru...gti-62120.html
and then DIY matte black paint ?
i'm not 100% sure if they'd fit the bora though; they're off a Polo GTI and he says he thinks they're 5x100 but doesn't the wheel guide say they're 4x100 ?
yeah, you're right. Offset is 45mm though, and bora has 57. does that mean I need spacers ?
Polo PCD is the same as bora.
hub centre should also be the same.
check offsets, but should not be any real dramas. spacers if needed
as above
PCD should be ok. centre bore should be ok. offset SHOULD be ok... your wheels are 16x6.5 et42 IIRC, so those wheels are close... but its worth finding out the exact details and we can help you out and tell you exactly how they will fit
Get him to confirm the width and offset
no worries, cheers for the info. i'll have a squiz under the wheel tonight (or maybe tomorrow; it's raining and 5C here :( )
EDIT: noob question: does that mean the new wheels have to be 42mm as well ? Or can they be anywhere between 42 and 57.1 ?
57.1 is your centre bore, nothing to do with the offset.
centrebore is the hole in the back of the wheel.
but no, your offsets dont have to be the same. and offsets are useless without widths, you need the two.
no stress pulling your wheel off. send me a PM when you find out the specs of the polo wheel and ill let you know the details rather then filling up this thread.
