It's due to the pad material used in VAG vehicles.. When you pads are due for replacement you can ask your local mechanic to use a pad with a lower dust material.
Hello everyone,
This is probably a silly question but is it usual to have extremely dirty wheels after a week?
It seems as though every weekend I am cleaning my rims because they are almost a charcoal colour (originally light silver). Today whilst cleaning them, I wondered if it was normal to have such dirty wheels on a regular basis as I only drive on roads and don't even drive that much.
The front wheels are the worst and the bucket of water needs changing after each, the back wheels aren't as bad but still need a clean. It is a diesel so I though this could be why but they get so dirty very quickly.
Once again, you probably think I'm an idiot for asking but I've never had a diesel before so I really don't know.
Thanks in advance,
Chelsea![]()
2009 2.0 TDI Pacific Golf Comfortline
1968 1500 German Beetle
1964 1600 twin port Deluxe Beetle
Ok. Thanks!
I'll be waiting a while because she just got new brakes. I didn't know that option was available.
Original equipment (OE) brake pads and discs on modern European vehicles are designed to offer good braking performance at high vehicle speeds and good pedal feel. However, this comes at the cost of increased wear rates, as evidenced by the rate at which the wheels become soiled with pad and rotor material.
As with almost every passenger vehicle, the front brakes do most of the work due to weight transfer under braking, so the front brakes will wear faster. Thus, the front wheels tend to become soiled quicker than the rear wheels.
Ceramic brake pads can offer better resistance to wear and the material they shed is less noticeable, as it's lighter in colour. When the vehicle needs new brake pads again, you might want to check out some of the aftermarket ceramic options from Akebono, ATE, Hawk, Textar and others.
ATE Ceramic pads from HSY - best thing i ever did
