Results 1 to 5 of 5
Thread: Cutting bump stops
    Gold Coast
    Cutting bump stops
    Is it possible to cut my bump stops in half without taking the coilovers off the car?
    Sep 2006
    West Sydney
    You'd risk scratching the shock piston. And you'd have to cut a slit down to actually remove it. More of an annoyance than anything.
    Sep 2009
    Easy really. The shock piston things are very tough so I wouldn't be too worried about scratching them, just be carefull. I took mine out to cut mine though.
    Did cut the helper springs off with an angle grinder though, in an attempt to keep some sort of alignment
    sydney
    I have used a loose hacksaw blade to cut them on the car, just get a fine tooth blade. Cut horizontally around the strut and then you can push the sliver up and slice it down the side.
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Gold Coast
    Quote Originally Posted by sortofbigbj View Post
    Quote Originally Posted by alex g View Post
    Cheers fella's, i'll give it a go.
