PM Quozl (Al) I know he has done this on his R32 Targa racer...
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
id be keen to know this also...
yeah I was looking at those Driven Performance adaptors you put me on to then realised I'll need to run studs cos if I use the standard bolts on the adaptor they might not sit flush enough to let the wheel mount.
Though they might just sit in the scalloped parts of the wheel so might be alright.
already will be running 20mm of poke can't go up to 25mm adaptors.
You will have no problems I did this with the mk1 with the hotwires no probs at all.
Even when the mk3 had the porsche wheels off the adaptors I was rolling around fine
What suspension will you be coulping this with?
I assume that the poke means a high chance you will rub on the lip?
