Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Converting to studs and nuts
    S.E Melbourne
    hey just wondering any downside issues I should be aware of when converting from bolts to studs?
    I'll have to run studs and nuts to use the 15mm adaptors for my new wheels.
    any advice, abuse, sexual innuendoes welcome.
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
    Aug 2007
    Five Dock, Sydney
    PM Quozl (Al) I know he has done this on his R32 Targa racer...
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    id be keen to know this also...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    S.E Melbourne
    yeah I was looking at those Driven Performance adaptors you put me on to then realised I'll need to run studs cos if I use the standard bolts on the adaptor they might not sit flush enough to let the wheel mount.
    Though they might just sit in the scalloped parts of the wheel so might be alright.
    already will be running 20mm of poke can't go up to 25mm adaptors.
    Sep 2006
    Australia?
    You will have no problems I did this with the mk1 with the hotwires no probs at all.
    Even when the mk3 had the porsche wheels off the adaptors I was rolling around fine
    S.E Melbourne
    sweet all I wanted to hear, figured there would be no issue... now to loose some money.
    Quote Originally Posted by Whubbsie View Post
    NICE!!
    My fronts are 20mm adapters with no scallops so im stressing about that, more then the 15mm adapters on wheels with scallops.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    S.E Melbourne
    if the fronts are flat just get them redrilled? would be easier then wouldn't it?
    oh and i calculater wrong will me 25mm poke
    Jan 2009
    blankedy
    What suspension will you be coulping this with?
    I assume that the poke means a high chance you will rub on the lip?
    S.E Melbourne
    already rubbing with a full car load
    will probably end up running narrower tires which will help.
    on h&r and saggy stock shocks though, looking into stiffer lower spring too.
