Originally Posted by
Flat-Mango
My understading is that coilover springs are universal,
As dylan8 has said, nothing could be further from the truth.
If you alter the spring rate, then the dampers need to be revalved (or adjusted) to suit. In your case, the damping would end up far too harsh and you would have a very jarring ride (it'd be tied down well, though).
Resident grumpy old fart
