Not your fault - if that çunt handn't stolen your OEM wheels/tyres while you opened up your roller door, you'd be able to swap things around like me.
But change your torque arm bush back to rubber fer chrissake!! I used mine for yesterday's track day and hated every moment with it when not actually on the track.
Resident grumpy old fart
