Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Coilover spring replacement.
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Buller_Scott View Post
    you dont.
    i regret NOT doing this.
    Not your fault - if that çunt handn't stolen your OEM wheels/tyres while you opened up your roller door, you'd be able to swap things around like me.
    But change your torque arm bush back to rubber fer chrissake!! I used mine for yesterday's track day and hated every moment with it when not actually on the track.
    Resident grumpy old fart
    melbourne
    Quote Originally Posted by kaanage View Post
    i think, after installing a SMF, i just might have to... i predict things will get pretty unbearable, even for me.
