wont be sway bar on drive shaft in a 4mo bora
when you say wound down all the way, do you mean you have the helpers out too?
if you are wound all the way down in the front it could be wheels/tyres interfering with the strut/adjuster/spring
because if you actually have them all the way down the car must be near touching the ground from what I have seen of trickysimon's bora
did you replace strut top bearings and bushes when installing the coilovers. thats always the first thing to look for.
