Page 2 of 16 FirstFirst 123412 ... LastLast
Results 11 to 20 of 158
Thread: CHINESE TYRES vs BRAND NAME
    Apr 2017
    belgrave victoria
    Indeed i for 1 am interested in the long term result it will def be a long term result 5000k+ to really determine the outcome
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Sep 2015
    The only thing I can add is from the mouth of a mate who was a franchisee from one of the major tyre chains.
    I asked him about Chinese tyres a few years back and his comment was at the time they were fairly good value for money. Most of the factories were new and producing tyres that were close to their intended tolerance, so from a manufacturing perspective (one of the concerns a lot of people have about Chinese products) they were good.
    The unfortunate part of Chinese manufacture is their willingness to substitute (as Mattel (or Google it) about substituting lead based paint on toys). This means although the goods are well made and within tolerance the material used might be sub standard.
    So you get what you paid for (maybe a little more due to the good tolerances). Let the buyer beware. Did I/ Do I/ Will I buy Chinese tyres? No.
    May 2017
    Central Coast, NSW
    Keen to hear the outcome, mate. I for one am always glad to see small startup companies compete with the legacy brands, even if they're from China. Society's obsession with brand names and labels costs us extra in the long run, for sure.
    2017 - Golf R 7.5 - Blue - DSG - Proper Roof - DAP - Res' delete - Dynaudio delete
    2008 - Mazda 2 - (Maybe my first child scared me a bit) -1998 - Wrx (modded up to but not including forged pistons)
    1988 - Corolla TwinCam - (couldn't insure a 323 Turbo)
    1967 - Tonka Tip Truck - Red with 2 inch plastic rims and a massive sand scoop.
    Dec 2006
    Kilsyth, VIC
    How many dollars are these tyres actually costing? I know you've said 1/3 - 1/4, but what is that in actual dollars? This allows us to compare them more easily to other things that might be available. I'm running RE003's in 225/40/R18 which cost me $980 fitted (in september 2015).
    Having read one to two tyre reviews over the years as well as talking to people around the industry I've come to understand a few things.
    Reputable tyre tests are usually done in a reasonable fashion, but they also tend to source tyres directly from the manufacturers which means you're getting brand new fresh tyres which isn't always the case in your local shop (depending on how popular they are they could be older stock). This means that they will be performing as well as they ever will and will only get worse over time...
    In very broad terms tyres that grip better are softer and wear faster vs harder compounds which wear really well as the expense of grip. It's also worth noting that soft tyres tend to get harder as they age so you want something that maintains it's properties over it's useful life.
    For those reasons (and as someone has already said) even low KM cars should have their shoes replaced at regular intervals to ensure the tyres are still doing their jobs.
    Here is one example of some testing that's worth having a look at, it's last years test as I didn't see this years online yet.
    Best Performance Tyres Test 2016 | MOTOR Performance Tyre Reviews | MOTOR
    In any case it's interesting, there is about 20% in both wet and dry braking tests but it's less than 10% for the other tests. In real numbers that is 13.96m in the wet braking test vs 16.54m and 34.75m vs 41.75m in the dry tests.
    Here is another one:
    The best and worst tyres for your car
    This review includes at least a passing reference to an old tyre. It doesn't say what brand/model it is, but the summary was it was reasonable in the dry but sucked hard in the wet, presumably this is simply down to the amount of water able to be displaced by the depth of the tread (or lack there of).
    I'd love to see the same tests done to the same tyres in 24 months or 20,000km or something to get a real world story on age.
    Here is another article talking about older tyres and little about the science:
    How Old - and Dangerous - Are Your Tires?
    and another:
    The Science of Tire Aging
    Bottom line, normal people are unlikely to ever be able to test more than "seat of the pants". Those 10% differences in driving are unlikely to be really felt on the streets. Even the 20% difference in braking is only a couple of car lengths and aren't the sort of thing you tend to do in real life (except when it's probably more important that it all works... like in an emergency). It would be great to see this end of the market included in some of these more scientific tests.
    It would have been interesting if the OP has done a few dry brake tests on the old tyres then the same on the new ones at the same location... but then finding somewhere it's safe (and/or) legal to do that can be interesting too
    Again, for most people, most of the time anything round and black is probably OK as we tend to not drive to the limit or be put in situations where it matters too much.... but then it's sort of like insurance. You don't pay for it because you think you won't crash, you pay for it in case you do. Plenty of people choose to self-insure and come out in front, even after an accident... others hit a Porsche on the way to the shops.
    nsw
    I think the reaction of some people on here at what your doing come from the fact that the '10% of people' thing might apply to camry's etc but you're in a mk7 golf R doing some serious speeds in the blink of an eye, which kind of changes the risk/benefit relationship. A lot can go wrong fast and is more likely to with turd tyres. You can feel even premium brand tyres go off over time. There's also the simple fact that if you're under the load and speed ratings of the oem tyres and have a big one, the insurance company could wipe you.
    Jul 2007
    Brissy
    These tyres might be good, who knows.
    I remember when Kumho came on the scene, they were rubbished.
    Personally I got some with new wheels. I thought they would be crap. I got 50,000km on the 1st set and went on to own 3 sets in a row. After having many top brand tyres before them I was well placed to compare. They gripped as well as the expensive ones in the dry, not quite a good in the wet and lasted a lot longer, like 50,000km+ compared to 10-14,000km on Michelin & Pirelli.
    Over time the Ku31 became the go to value sport tyre, getting great reviews and recommendations by forum members everywhere.
    As for issues with safety, so long as they meet the speed & load ratings insurance etc should be fine.
    Remember just a few PSI on pressure can turn a top tyre into an unsafe tyre. So it is not just the brand that make things safe.
    If you save a bundle on them and they are good, that is great. If they suck you may have got what you paid for. No loss really.
    Some food for thought...
    Pirelli is a Chinese owned company, they make Bridgestone, Michelin, Continental and Goodyear.
    So are Chinese tyres safe ??
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    They'll own everything at some point.
    So to dismiss a 'brand' as Chinese and therefore crap is pretty naive.
    Look at how Volvo is performing under Geely. Chinese ownership means access to capital not poor quality.
    Jun 2007
    Quote Originally Posted by JustCruisn View Post
    You sure of that? I know the Chinese bought Pirelli a couple of years ago but I'm not sure they own the other brands you listed. Happy to stand corrected if you're sure of that.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Nov 2015
    I believe that Pirelli is now owned by ChemChina but I thought that Bridgestone tires were made by Bridgestone Corporation (aka Kabushiki-gaisha Burijisuton) which I understand is a public company, listed on the Tokyo Stock Exchange. I believe that some of the cheaper Bridgestone tires we get here in Australia are made in their Thailand factory. I also believe Michelin is a French publicly listed company, listed on the EuroNext, I assume that they make all their own tires. Continental a German publicly listed company on the Frankfurt Stock Exchange, I assume that they make all their own tires. Goodyear is an American publicly listed company on the NASDAQ and I assume that they make all their own tires.
    Disclosure - My Caddy runs Michelin XM2s, my Golf Mk3 CL is running Bridgestone MY02s, my Vento GL is running a mix of Kumho and HiFly (chinese tires), and my wife's Golf Mk5 runs Bridgestone RE003 (235/45 R17).
    My wife and I like the RE003s, they seem to give good performance at a good price. Very good in the dry but can aquaplane a little bit in the wet, so need to back it off just a little bit in the wet. I just wish they had a bit more treadwear to them.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Feb 2015
    Sydney, Australia.
    Quote Originally Posted by The_Hawk View Post
    and another:
    $95 per tyre installed. compared to michellin or goodyear $300 - $400 tyre per installed depending on which model you go with
