Results 1 to 8 of 8
Thread: Golf V rear swaybars
    Jan 2008
    Sunshine Coast
    Given the understeer characteristics of the stock GT golf, I was wondering:
    1. Is the rear GTI swaybar any beefier?
    2. Where can I get a beefier rear swaybar from over here? Reluctant to just front up to Pedders and watch them scratch their heads at a VW....
    I'm after more neutral handling, nothing drastic.
    Smile
    Try Whiteline they seem to make a full range of bars.
    www.whiteline.com.au
    Nov 2007
    Perth
    Neuspeed you can get through Rennenhaus:
    http://www.rennenhaus.com.au/MK5Suspension.html
    H&R also make them for the MK5 - you can get those through GC Corp (who also sell the Whiteline gear)
    http://www.gccorp.com.au/automotive/...p?cPath=43_117
    Remember to factor in local installation $, unless you want to jump in and DIY.
    The rear sways are supposed to be relatively easy, assuming you're not too hamfisted
    May 2007
    Moorooka, Qld
    I've got a white line bar on my Astra & a Neuspeed bar on my passat.
    The neuspeed is a better engineered product than the whiteline. The whiteline bar was $220 & the neuspeed around $520. The little brackets that hang down from under the shock mounts - in the neuspeed kit they're a kind of ball joint arrangement with adjustable length. In the whiteline kit they were a figure 8 with two urethane bushes. The whiteline kit in the astra doesn't mount in the rear axle either. The neuspeed brackets clip over the rear axle. I think in the case of the astra this is common to the breed. UK after market rear bars mount the same way.
    Performance wise - its not apples/apples. The astra has stock everything else but the passat has coil overs. I think though that the weight distribution is better in the astra & the car is heaps shorter. This made the addition of the rear bar a lot more noticeable. This would be similar to a golf esp. if you have a lateral mounted engine (ie better weight distribution).
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by xcgumby View Post
    Thanks a heap for your input mate. Given the big cost difference, it's nice to hear the real world view. Sounds like you are saying the cheaper set would be fine for a smaller more balanced car, such as the golf. I'm pretty impressed with the stocko handling to be honest, I'm just after a bit less understeer and a little less roll.
    Jan 2008
    Sunshine Coast
    H&R seem to be a nice mid priced bar, the whiteline looks fine, but is welded whereas the H&R and Neuspeed are forged units from overseas as XC has mentioned. For the little extra the H&R is looking good. Only drama is the stock rear is 21mm, and everone only offers 22mm or 24mm options. 22mm is only 20% stiffer, but 24 is a whopping 71% ( phew ).
    I'll go for an adjustable though, as 24mm may be a bit too much... especially since the stock front is only 25mm. I guess I can always upgrade the front too, but I'm not after a go-cart.
    thanks again guys!
    I'll give them a call next week.
    Jan 2008
    Perth, WA
    There are several write ups of various suspension bits and pieces, including the pros/cons of just getting the rear bar, if you look at the Australia section of the golfmkv forum.
    Jan 2008
    Sunshine Coast
    Thanks lads, I'll do some research on those links and let you know how I go.
    A swaybar fitment should be relatively easy like you say.
    cheers!
