Results 1 to 10 of 13
Thread: Centre Bore Question
    Aug 2012
    Blackmans Bay, TAS
    Noob as question. What if any issues would come from using a wheel spacer with a Different centre bore than the one specified for your vehicle?
    Either won't fit if its too small, or cause vibration depending on thickness
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2012
    Blackmans Bay, TAS
    Ahk, I'm lost though.... It says that the centre bore is 1mm less, but it more than clears the hub....? (By at least 10mm). If the stud pattern is correct how would there be any problem with it being centred??
    Oct 2010
    Melbourne, VIC
    It should be like running non-hubcentric spacers. I wouldn't do it but then I wouldn't run hubcentric spacers, either.
    Resident grumpy old fart
    Aug 2012
    Blackmans Bay, TAS
    Quote Originally Posted by kaanage View Post
    What are the dangers of running both hub enteric and non hub enteric spacers? I need to run some sort I spacer to clear brakes
    Jan 2009
    blankedy
    Legal (check your state's laws)
    can break, cause an accident (there is a thread on here currently about spacers cracking / breaking)
    could allow movement where there is not supposed to be any, which may damage the hub, bolts, etc.
    Its hard to say, could be fine, could be disastrous. If you are going to use them, at least get good ones with suitable bolts.
    Im guessing you have found some cheap/second hand.
    just buy some with bolts suited to your car... dont muck around with stuff like that
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2012
    Blackmans Bay, TAS
    Na i found new ones. What is considered cheap? $80 each? Where can I get some quality ones?
    brisbane
    Aug 2012
    Blackmans Bay, TAS
    Are bolt on spacers less dangerous than slip ons? I get the fact that slip on spacers can be pretty dangerous, but surely bolt on are much safer?
