Easy enough to make. Plastic would be easily enough moulded if you wanted to make lots.
If I was doing them in metal I'd probably use 0.5mm sheet, cut a strip, roll it & braze or silver solder the butt joint & file it smooth & slide it over the hub as a firm press fit. You could machine it on a lathe as well but forming from strip would be achievable at home in the garage and the material would be cheaper.
The other thing you could do is just suck it & see. If it feels good then go no further. My Golf only had 2 hub rings & was fine all the way to $160
