Results 1 to 7 of 7
Thread: center bore and hub size conversion
    Sep 2008
    Sydney!
    this question has prob been asked before but what's the process of changing the hub bore size of a bss wheel from a subaru 16"x6.5" Offset +55 to fit a vr6 wheels pattern? is i worth the time money and effort or do you end up spending that money it get it working its not worth it in the end?
    White 95 vr6, colour coad, koni, neuspeed, 16 x 9, samco!
    Jun 2007
    Eastern Suburbs Melbourne
    centre bore is too small, so it needs to be widened. and you'll need a spacer to lower the offset. about a 20mm spacer should be able to do it. dont know why you'd change to suby wheels if you're already running 16x9's!
    i like volkswagens
    Dec 2007
    Ermington, Sydney
    if the bore is too big, you'd just run hubcentric rings, so that the wheels fit.
    if the bore is too small, you'd just get the bore machined out which wouldn't be too expensive.
    seeing as the offset is 55 anyway, you'll probably need like 20mm spacers at least bro!!!!
    Sep 2008
    Sydney!
    ok thanks, yeah its just my mate is gettin rid of a set of bbs wheels from his suby just curious to see how they would of fitted up as a 2nd set of wheels
    Sep 2008
    Sydney!
    Quote Originally Posted by Mrk_Mickey View Post
    cheers thanks mickey!
    Id ran adapters dude, fixes the spacing and the centre bore. Adaptec do custom ones and are about the same price as off the shelf ones and you can have them to almost any spec.
    Getting the centre bore machined out ($15 a wheel) and some off the shelf 20mm spacers (~$50 each) would be alot cheaper than a custom set of Adpatec spacers.
