Results 1 to 10 of 16
Thread: Can't wait to get my Yokohama ADVAN Neova AD08's installed!
    Oct 2011
    Atwell, WA
    Talking Can't wait to get my Yokohama ADVAN Neova AD08's installed!
    Hi All,
    Getting my AD08's fitted on Thursday @ Bob Jane in Cannington
    Can't wait, been quoted ~$1200 fitted which I'm happy with...
    Coming from the standard Dunlop's on the GTI I'm thinking its a worthwhile upgrade...
    Cheers,
    Josh
    2012 Volkswagen Polo GTI (Shadow Blue) | Current Upgrades - APR Stage 2 Tune | GFB DV+ | HP Cold Air Intake | OKADA Plasma Direct Coil Packs | HP Exhaust | HP DQ200 Tune | Whiteline Rear Sway Bar | Uprated Engine Mounts Planned Upgrades - | Coil Overs | HP Intercooler |
    May 2013
    Hervey Bay, QLD
    Let us know how it goes...noise, handling wise.... Have used the Yokohama C Drives in my previous car...
    Harry
    MY13.5 Red Polo GTI
    Harry
    MY15 RED Polo GTI 6C - with DA Pack
    Feb 2008
    ACT
    I'm sure you'll love them!
    I swapped from Pirelli P Zero Corsas to the AD08s on a previous car and found them to a great upgrade all round - improved wear, better wet weather grip and very little fade when driven hard on the track.
    Very interested to hear how they go on the Polo.
    Jun 2009
    I have heard the new AD08R's are a spectacularly good tyre, a step up on the 08's.
    Jan 2011
    Brisbane - QLD
    the AD08 is as close as you can to semis (real semis with wear rating of <100).
    i had the AD08 before and used the set on track and absolutely loved them! currently trialing the cheapest option but the same class, Kumho KU36.
    noise, definately louder than any non extreme performance class tyres, but acceptable while cruising on the highway at 100-110 kph. the KU36 is louder than AD08.
    handling, the AD08 has steel insert in its sidewall for stiff sidewall. the KU36 has softer sidewall.
    stickiness, the AD08 picks every small loose rocks and gravel when warm and yes you can hear them spraying your inner fender liner
    in summary, if you want grip, handling and have plently of $$$$ and don't care about wear rate and comfort; get the AD08
    Demon Tweaks UK sells the cheapest AD08.
    MINI Cooper S Clubman - FWD
    Jan 2009
    The Advan Neova AD08 tyres will finally allow you to take better advantage of all the mods you have on the car, especially the power and brake upgrades.
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by nat225 View Post
    I would not rely on wear ratings as an indication of performance or "stickyness"
    But there no question or doubt that the AD08 is a performace tyre
    Quote Originally Posted by RandomX View Post
    I had a puncture repair at Bob Jane in Sydney
    Months later when I needed to remove the wheel I discovered the bolts were massively over tightened
    So much so that I sheared the bolt head off a wheel brace trying to undo them!!!
    Oct 2011
    Atwell, WA
    They have actually fitted AD08R's so that was a nice bonus
    These tyres are amazing! Much much better wet performance which i wasn't expecting
    Can't give any feedback to dry performance yet... Damn rain...
    Car is much more controllable, steering feedback is improved...
    Very happy, a worthwhile investment if you have some $$$ for your car...
    Aug 2012
    Albury, NSW, Australia
    I know they are just tyres but pics anyway?
    Jul 2013
    Caulfield, VIC
    Whats the best 3 or 4 tires you guys would recommend for my car? I dont do track days, just want something to grip really well on dry mountain roads, and emergency brake better than stock in the wet commuting. Have had $150 tires in the past, looking at upgrading to the $200-220 mark.. Cheers!
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
