I'm running 18x8 karthoums with a 52 offset which is the widest available oem wheel vw Australia sells.
You will have 12mm extra in the rear which will mean u will sit perfectly flush with the top of the rear guard.
At a guess in the front you will be either flush or sit out of the guard by like 2mm.
IMO it will be perfect fitment.
Oh and I'm pretty low on fk coil overs, my only reason for not going lower is that my current tyres are too fat and scrub so later on I will be running a little stretch to clear the inner guards.
White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
