Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: camber wear wen lowered
    Aug 2006
    how do u's with lowered dubs fix it? my inner sides of the tyres are wearing out fast!
    all 4 tyres!
    Sep 2006
    West Sydney
    Camber kits? Basically just a bolt with some hinges in it that allows you to set the camber closer to neutral.
    Aug 2006
    who sells them?
    Sep 2006
    West Sydney
    I remember Pedro buying a pair for the front for his Mk3 at Whiteline's headquarters (Minto I think).
    syncro Guest
    Why can't you just get a wheel alignment? Camber is adjustable.
    Aug 2006
    searched the forums and found passat camber is not adjustable. need some kind of kit. damn sounds expensive.
    Oct 2006
    $72 from whiteline, go give em a call. Can also get noltecs too but ~$90 i think, then get a wheel alignment after and ur good.
    Sep 2006
    Parkinson / Brisbane
    There not that expensive? though neg camber looks sickness i have neg2 on mine and its wearing faster on the inside but handles soooo much better! . . .
    Sep 2006
    West Sydney
    The kit is merely a modified bolt! So I guess for what you're holding in your hand, it's pretty expensive., though will definitely be cheaper in the long run.
    syncro Guest
    I find it hard to believe that the camber is not adjustable. I've heard that myth about Golfs also.
