Camber kits? Basically just a bolt with some hinges in it that allows you to set the camber closer to neutral.
how do u's with lowered dubs fix it? my inner sides of the tyres are wearing out fast!
all 4 tyres!![]()
who sells them?
I remember Pedro buying a pair for the front for his Mk3 at Whiteline's headquarters (Minto I think).
Why can't you just get a wheel alignment? Camber is adjustable.
searched the forums and found passat camber is not adjustable. need some kind of kit. damn sounds expensive.
$72 from whiteline, go give em a call. Can also get noltecs too but ~$90 i think, then get a wheel alignment after and ur good.
There not that expensive? though neg camber looks sicknessi have neg2 on mine and its wearing faster on the inside but handles soooo much better! . . .
The kit is merely a modified bolt! So I guess for what you're holding in your hand, it's pretty expensive., though will definitely be cheaper in the long run.
I find it hard to believe that the camber is not adjustable. I've heard that myth about Golfs also.
