Results 21 to 30 of 35
Thread: camber wear wen lowered
  1. #21
    Aug 2006
    man that doesnt look easy to install.
    i will get a 4 wheel allignment and hopefully it fixes it self. how would i tell if it fixed or not after allignment?
  2. #22
    Oct 2006
    If camber cant be adjusted a wheel alignment wont do squat. I found that out having forked out the $50 when the guy told me and i had to fork out another alignment after installing the camber kit.
    Its relatively easier to install if u buy the noltec/whiteline one. All you do is pop front wheels off, remove the top strut bolt and insert the replacement one. Then get a wheel alignment and they will correct the camber.
  3. #23
    syncro Guest
    Quote Originally Posted by peedman View Post
    If that was on a Golf 3 front you've been ripped off. The camber is adjustable by the lower bolts.
  4. #24
    Oct 2006
    How is it adjusted? Theyre just normal bolts
    edit: ok i read theres some adjustment on the lower bolt lol, oh well mine does the job too
  5. #25
    syncro Guest
    This is why I hate most mechanics.
    It's very hard to find someone to do a wheel alignment.
  6. #26
    May 2006
    Maroubra NSW
    By tracking I mean having the front wheels set parallel (or as per the book if you have that info).
    The front wheels should always have a small amount of toe in, to make the system stable. Not sure what is the nominal for road vehicles, but it's a definite requirement. (Can explain the theory if you really want!)
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
  7. #27
    Quote Originally Posted by smithy010 View Post
    http://www.ozebiz.com.au/racetech/theory/align.html
    Remember also that toe will change slightly from a static situation to a dynamic one. This is is most noticeable on a front-wheel-drive car or independently-suspended rear-drive car. When driving torque is applied to the wheels, they pull themselves forward and try to create toe-in. This is another reason why many front-drivers are set up with toe-out in the front. Likewise, when pushed down the road, a non-driven wheel will tend to toe itself out. This is most noticeable in rear-drive cars.
  8. #28
    Sep 2006
    West Sydney
    Are you sure it's toe-in? I thought it was a slight toe-out for front-wheel drive vehicles as they tend to toe-in when under power (so that they'd be parallel when moving), and it's the opposite with rear-wheel drive vehicles as the front wheels are being pushed rather than driven. I don't know how that works but I just read somewhere.
  9. #29
    May 2006
    Maroubra NSW
    I'm not sure about that. For road vehicles, toe in is a general rule. The overall rule is that steering will not track correctly if parallel. It is better if the wheels are aiming at a common point off in the distance. Toe out works similarly, but i believe that it is used a lot in Track racing vehicles to effect a greater angle of attack in turns (in combination with positive ackermann).
    Anyone who knows more about the differences in fron/rear wheel drive vehicles, i'd like to know.
    Enough technical talk.
    Smithy
  10. #30
    syncro Guest
    I'd like to know more about your ackermann.
