I know what a camber bolt is...
Volkswagen Golf II 8v > Suspension > Camber Kits > ES#1023 H&R Triple C Camber Bolt Set - TC212
I had a wheel alignment done on my MK2 yesterday and they told me the front right had more camber than the left.
Right -1.18
Left -0.40
This is making the car to pull to the left slightly.
They told me i would need camber pins to fix it. I have no idea what camber pins are or where to source them. Any ideas?
It's running coilovers by the way.
Most cars have an adjustable camber pin from factory, did they try that. That's assuming VW's run them.
Do your coilovers have adjustable tops?
Golf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
a camber pin is usually just thinner bolt. The camber bolts like mik posted above have the eccentric. I thought mk2s come from the factory with eccentric bolts?
I have a set here which you can have for $50 if you need them. They have only seen 1 weekends of use
You need to ask the place what if any adjustment they got out of the existing ones. Also do the coilovers have adjustable tops?
They are usually the top clevis bolt, but both look the same - same head size. Ask the place you went too what adjustment they got out of the the existing one? See if they are bull*****ting or not.
