Results 1 to 7 of 7
Thread: Camber Pins?
    Gold Coast
    Camber Pins?
    I had a wheel alignment done on my MK2 yesterday and they told me the front right had more camber than the left.
    Right -1.18
    Left -0.40
    This is making the car to pull to the left slightly.
    They told me i would need camber pins to fix it. I have no idea what camber pins are or where to source them. Any ideas?
    It's running coilovers by the way.
    Jul 2005
    Newcastle, NSW
    Sep 2011
    Gold Coast, Qld
    Most cars have an adjustable camber pin from factory, did they try that. That's assuming VW's run them.
    Do your coilovers have adjustable tops?
    Golf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
    Point Cook, Vic
    a camber pin is usually just thinner bolt. The camber bolts like mik posted above have the eccentric. I thought mk2s come from the factory with eccentric bolts?
    I have a set here which you can have for $50 if you need them. They have only seen 1 weekends of use
    FOLLOW US ON FACEBOOK
    Sep 2011
    Gold Coast, Qld
    You need to ask the place what if any adjustment they got out of the existing ones. Also do the coilovers have adjustable tops?
    Gold Coast
    Quote Originally Posted by PTW View Post
    Nope, no adjustable tops. Not sure if they even adjusted them, is there a way to tell?
    Quote Originally Posted by Tim View Post
    I'll have a look at what is on the car and get back to you. Out of curiosity (and necessity) where are they located?
    Sep 2011
    Gold Coast, Qld
    They are usually the top clevis bolt, but both look the same - same head size. Ask the place you went too what adjustment they got out of the the existing one? See if they are bull*****ting or not.
