Results 1 to 10 of 12
Thread: Bumpstops
    Sep 2006
    West Sydney
    Bumpstops
    Is this a "just-opened" section? Anyway, just realised this so I thought I'd make a post.
    Bumpstops - do we need them? What are their functions? Would you need shortened ones if you fit on lowered springs? I've had mixed answers before, but want to know what your opinions are.
    Oct 2006
    Yes u do. I was told by mechanic at work that they prevent the shock from bottoming out thus ruining them.
    Shortened ones, i got no idea.
    Ps: yes it would have been smart to replace mine
    Aug 2006
    how do these bump stops look like?
    Sep 2006
    West Sydney
    In the fronts of my Mk3, they're basically a plastic cover that sits on the spring plate. The rears consist of a plastic cup with a rubber "damper".
    They're basically covers that go "inside" the springs and sit on the spring seats. I bought a set from a parts dealer and he was actually telling me that I didn't really need them.
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    I thought that bump stops were rubber bits that go onto the shock absorber, stopping the shocks and springs from hitting a certain point and stoops the car from bottoming out too? e.g, like if the car is lowered, and you go over a speed hump, it will stop the wheels from fouling the arches or rubbing etc....
    Oct 2006
    Yeh the ones u bought with me are correct, exactly as pommy describes. For the front shocks they look exactly like the rears except are heaps smaller - then the plastic dust cover goes over that.
    http://www.mjmautohaus.com/catalog/i...1H0412303B.jpg
    Gosford Central Coast NSW
    Quote Originally Posted by rayray086 View Post
    sorry mate, incorrect
    bump stops are rubber bushings that slide over your shock absorber shaft, limiting the maximum downward travel of the suspension.
    you definately need them, they are a good idea.
    you cant get lowered bump stops, they would be pointless.
    you will damage your shock absorbers if you don't have them and your suspension bottoms out.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Sep 2006
    West Sydney
    Ah, yes, my bad. Recall now that the things I mentioned were the dust boots. Just that I've read on the vortex that quite a few people on lowered suspensions cut off one or two "bumps" to "accomodate" for the drop... they've poisoned my mind
    Thanks for your replies. My bumpstops will not be mutilated and will stay where they are!
    You can get poly ones which are designed to be used with short stroke shocks. Not good to use the originals and then be riding on them constantly.
    If you do bin them and bottom out a shock on a bend there's a good chance that a trip to hospital will be on the cards. We did this with a mates Scirocco years ago. Chucked away the rear stops cos they were Donald Ducked. The following day hit a bump on a nasty bend and as it bottomed out the rear end flicked out.
    A trip to the dealers at dinnertime to get new ones prevented a repeat episode.
    Hey guys,
    Rather drag up an old thread than start a new one. My bumpstops on the rear wheels need replacing, I was just wondering where abouts I would need to go to get some more in Adelaide??
    Are they easy to install yourself?
