Results 1 to 10 of 19
Thread: Brake Pad Replacement
    Nov 2007
    I couldn't find a designated spot for this tread...So, I figure here'll be okay for now.
    My rear left pad needs replacing and was wondering if I could do it myself without forking out cash to get it done elsewhere. Is there a specific tool that I need? Anyone care to take me through the process?
    Thanks,
    Now owns a golf. Stoked.
    Dec 2007
    Ermington, Sydney
    You're doing this on your mk3 right? It's real simple
    Jack the car up and take the wheel off (If you're replacing the rear pad, leave the handbrake OFF)
    You'll need a 15mm open-ended spanner and either a 13mm socket or spanner (I think those sizes are right....give or take 1mm lol). You have to undo the caliper bolts, which are two bolts that hold the caliper onto the carrier. There's a rubber boot on the screwed-in end of them so they're easy to locate. This is one being undone:
    Once you've undone those two bolts, jimmy at the caliper and pry it off the pads/disc. The caliper can hang loose, and your brake pads will be ready to just take right off the disc Put the new ones in, push the caliper back onto the pads and tighten it as hard as you can tighten it, then put the wheel back on and you're done
    Gosford Central Coast NSW
    furthermore, you always replace the brake pads of an entire axel at a time, so you'll do both rear wheels.
    make sure that you check the brake fluid level after pushing the piston back into the caliper after installing the new pads.... or rather, put a rag around your fluid resovoir to catch any spillage.
    and dont forget to chock your font wheels
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jul 2005
    brakes
    Good luck pushing the piston back in on a rear caliper, it screws back in and if you open the bleeder it makes it a bit easier.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Camden, Sydney
    Yup you need a special tool not easily available in Oz. The piston has to turn and be pushed in at the same time.
    Nov 2007
    Thanks alot guys (Mr Mickey!)! Have to have a fiddle tomorrow!
    May 2007
    Jimboomba. QLD
    pad replacement
    How hard is it to push the pistons back in the rear calipers? If the tool is rare in Oz, how does everyone do it?
    I have a MK4 but by the pics I would say my calipers are similar if not the same.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Dec 2007
    Ermington, Sydney
    I've never had a problem taking the brakes off and putting them on at the rear, when does this problem come in? Is it when you put the handbrake on or something? lol.
    Boronia VIC
    You need this sort of tool.
    Routinely available on e-bay or specialist mechanics tools suppliers.
    http://cgi.ebay.com.au/WIND-BACK-REAR-DISC-BRAKE-CALIPER-SET-AMPRO-TOOLS-NEW_W0QQitemZ360129787006QQcmdZViewItemQQptZAU_Car _Parts_Accessories?hash=item360129787006&_trksid=p 3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A1 318
    I made up a tool out of an old brake pad and some threaded rod and other stuff I had lying about.
    Pete
    Quote Originally Posted by Mrk_Mickey View Post
    They mean when you try to push the piston back to fit new pad's.
    Not just take the caliper off & put it back on.
    As loon said, it has to be pushed & turned clockwise at the same time. not too easy at all without the tool's.
    You can buy the tool from VW (not cheap) or from oversea's to make it easier.
    Or as Pete has just posted. Locally!
    That's a bloody good price too!
    VW's own tool is way more than twice that amount & it's only to suit one car!
