You're doing this on your mk3 right? It's real simple
Jack the car up and take the wheel off (If you're replacing the rear pad, leave the handbrake OFF)
You'll need a 15mm open-ended spanner and either a 13mm socket or spanner (I think those sizes are right....give or take 1mm lol). You have to undo the caliper bolts, which are two bolts that hold the caliper onto the carrier. There's a rubber boot on the screwed-in end of them so they're easy to locate. This is one being undone:
Once you've undone those two bolts, jimmy at the caliper and pry it off the pads/disc. The caliper can hang loose, and your brake pads will be ready to just take right off the disc Put the new ones in, push the caliper back onto the pads and tighten it as hard as you can tighten it, then put the wheel back on and you're done
