Results 1 to 9 of 9
Thread: Brake Pad Dust Resistant Waxes
    Aug 2012
    Blackmans Bay, TAS
    Hey Guys, this may have been bought up before, but, i have all white wheels and obviously brake dust is a real issue. Short of changing out my (brand new) pads, any advice for reducing the amount of dust settling on my wheels? Or at least some recommendations for a good wax to make cleaning easier? I literally drive around the block and wheels are covered!
    Cheers!
    Mar 2010
    The Gyeon Rim Kit from site sponsor Car Care Products should work for you
    https://www.carcareproducts.com.au/p...protection_kit
    08 Golf GTI - SOLD
    Aug 2012
    Blackmans Bay, TAS
    Literally just ordered some! Thanks!
    Dec 2014
    Did it work?
    I cleaned and dried my wheels, applied the Gyeon Rim Q2 wheel sealant, dried the wheels in sun then baked them under infrared lamps for a couple of hours as per the Gyeon instructions. That was a month ago and so far I'm happy. The black brake dust washes off very easily. When the wheels are hosed the water beads. The treatment is supposed to last 6 months - we'll see!
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Adelaide hills, SA
    Why not fit the ATE Ceramic pads and have no dust and no mess in you driveway, if you wash car at home?
    I've fitted ceramic pads to all our cars and when I wash a car, I don't even touch the wheels, they're that clean that I just rinse them with water from high pressure cleaner.
    Oct 2009
    Mitchelton, Qld
    Transporter, what's the performance of the ATE Ceramics like? I've heard their braking ability isn't as great as non-ceramics?
    Aug 2013
    I had them on my CC with ATE discs as well. They were absolutely fine, and I usually push the car a bit. They were silent and dustless.
    Oct 2009
    Mitchelton, Qld
    Ok thanks Vexed.
