They are still a little tacky. The temperature was getting down in the late afternoon when I put the final coat on and it hasn't been over the 21C that they claim is the minimum temp to use the paint since then. Maybe I need to drive them and dry 'em from the inside
Did your mate's ones eventually dry?
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
We wiped them down with some thinner then recoated the calipers with the paint. We were thinking of just bolting on the wheels and give it a drive around as you say as well but then decided not to as we'd think the brake dust would just adhere to them (since they were tacky to touch).
Digging up an old thread. I did a cosmetic upgrade on my brake calipers on the weekend - painted the standard metal finish.
Pretty simple process:
1) Head down to your local auto store and buy a can of high temperature brake caliper paint (should be able to pick these up for around $20).
2) Remove wheels and clean brake calipers (degreaser + karcher high pressure cleaner), then allow to dry (or hit it with a heat gun)
3) Mask up everything that you don't want to get painted.
4) Paint away - lots of light coats to avoid paint runs
5) Wheels back on, stand back and admire your handiwork
I put the R decal on which is made out of heat resistant vinyl and then put a couple of coats of clear over the top.
We'll see how they go. Kept it stealth in black so as not to draw too much attention.
