what do you mean by camber kit Steve?
is that like a plate/spacer that angles the rear wheels so they tuck in the gaurd? if so i can deal with that
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
9" all around would just look awesome, but you may have trouble getting the fronts sitting right without rubbing.
For the rears, you can induce camber by a camber plate/shim that goes between the beam and the stub axle. For the fronts, camber bolts/pins can induce more camber.
cheers rayray
I woudl like 9's on the front but damn, i think i may be in trouble lol. so i was thinking about sticking with 7.5's and just add spacers to make it look more full...
Eric you probably won't need spacers for the fronts there is a fair bit of dish in those wheels
And yes as Raymond said its a plate with a small angle shim that gives you that slight camber![]()
Those rims are total sickness! You best be giving us pics when they're on!
Forever blowing bubbles.
Why the hell do you all go on about staggered rims and then stick the wider set on rear? Which has no drive? And the little ones at the front? Where the 128kw is sitting?? This makes no sense to me at all.
Oh and patience is my virtue tassie_euro_mk1 (that and I'm stone broke atm anyway lol!).
Coz u cant run 9" on the front without major stretching, rolling guards and camber....
well the wheels might have to be put on hold at the moment as the VR6 is showing signs of a blown head gasket
So if thats the case i will get the head ported/polished while its off.
Still gonna get the wheels tho. How fat is it gonna look from behind lol
