Head to a ricier suburb.![]()
If you have gone up in wheels size, you would have had the width increased and the profile lowered as well to keep the rolling diameter and load rating consistent with the OE wheel tyre combination. Fitting a narrower tyre with lower profile will lower both rolling diameter and load rating as I stated previously (and wai reiterated).
Have you checked with the store yet to find out the reason(s) for not fitting your preferred size?
If the store is the one in Mermaid Beach then they may be stricter than some others since that is a company run store while most are franchises.
Not necessarily. As a corporation, they have a lot of buying power which lets them negotiate good pricing with the tyre distributors which will more than offset the franchising costs (for the franchise stores) in many cases.
As with most purchases, get quotes from several stores in the area as they will all often sell for less than the listed prices.
