Results 1 to 6 of 6
Thread: boavista weight and offset question
    Jul 2011
    Hi all, I can't seem to find the weight of the 17" boavistas. Noone would know by any chance would they?
    Also, how much tolerance would I have with the et on after market wheels. I wouldn't see why 17" et 35/40 wouldn't work.. or would they poke out a bit much?
    what car are you putting them on?
    offset also means nothing without width, so need to post that up.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    actually just found this in another thread
    Comfortline with Sports Pack
    Wheel: 17" Boavista 17x7, PCD 5x100, ET46
    Tyre: 215/40 R17
    yes you can run different offsets and widths, how much depends on hieght, tyre size, and personal preference though.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2011
    Looking at replacing the boavista 17x7 et 46 with tsw nurburgring 17x8 et 45 on my 6r 77tsi. It will be getting lowered too. The offset question was just out of curiosity. I'm just after on the weight of the boavistas
    They'll be heavy... Probably the same or a touch more then the tsw
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2011
    If youre going 17x8 you'll need +35 offset because you won't have enough clearance on the inside. Go check the polo 6r section there's a recent discussion on wheels. And Bigfoot currently runs 18x8 et35 tsw nurburgrings on his polo with h&r lowered springs
