FSM, glad you're alright!
Thanks for the heads up.
I put on some 10mm Wheel/hubcentric spacers I bought off ebay on my front wheels a little while ago, but didn't take the car for a drive until today (as I only just got my license back today). I used proper extended bolts and they were properly torqued when I put the spacers on.
Less than 5 km's of driving today and bad things happened.
This is what's left of the spacer
Was very lucky I was only going slow and could pull over immediately when out of nowhere it got wobbly. Could have ended much worse.
Anyway just thought I'd share the photos. I certainly won't be cheaping out on spacers again, and wont be going with 10mm wheel centric either, they just don't work.
Driver Motorsport Tuned | Melbourne Car Meets | Insta: @VLNTVADERR
That, ladies and gentlemen, is why any component not covered by some sort of regulation, tends not to be roadworthy.
Anyone can make spacers and sell them - so whilst the results are disturbing, they're not surprising.
But the main thing is, you're not dead.
Yeah, best not to cheap out on anything related to wheels or tyres.
They're the only things keeping your 1.5 tonne machine on the road which, rather worryingly, few people tend to appreciate.
On the mk3 they supposedly can work up front, the description said they were to suit this exact model and I know the good brands make some that work. After having a good look at them I have a theory on how they broke, but I don't feel like typing it up on this phone.
Sent from my HTC Wildfire using Tapatalk 2
ask ebay/paypal if they will assist in getting you a deserved refund?
2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
+1 on the refund.
were they new?
Which needs to be automatically stated whenever someone comes up with the "Why are spacers illegal for aftermarket when Porsche use them on some of their models?" question.
In fact this thread should be linked in all those cases.
Hubcentric means that the hole in the middle of the spacer itself is sized so that it is located (ie centered) by the hub. You can get other spacers that have a massive center hole and are solely located by the wheel bolts or studs.
Resident grumpy old fart
I sent the seller a message with photos asking for a refund, we'll see what happens I guess. I bought them a few months ago and only just used them, so don't like my chances of eBay or PayPal helping, but I'll give it a try for sure. It damaged one of my wheels and possibly the hub (I haven't looked yet, but I have a feeling it may have a stripped thread on one of the bolt holes now) so a refund does seem fair.
Yeah they were brand new
