Results 1 to 10 of 13
Thread: Best tyre in 235/35/19 for 2011 v6 passat 3cc ?
    Jul 2010
    bracken ridge qld
    Hi
    just want a good tyre that is quiet but has good handling in wet and dry.was going to get the PS3 but not made in this size.
    whats everyones next best to the PS3? did search but couldnt find any info for this size.
    cheers
    warrick
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Jan 2008
    Canning Vale, Perth, WA
    I just imported 4 x Goodyear Eagle Asymmetric 2s in 235/35/19
    Sensationally good tyre, and arguably the best tyre in the wet.
    Best quote I could get in Oz was $650 each, so I got them from tirerack at USD176/each. Including airfreight to your door works out at around AUD285 each, and add $20 each for local F&B.
    http://www.tirerack.com/tires/tires....omCompare1=yes
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Jul 2010
    bracken ridge qld
    how do you find them for noise?
    thanks for the info
    cheers
    warrick
    Jan 2008
    not exactly sure - I have a nice loud exhaust!LOL
    Jan 2008
    here's tirerack's test comparison of them
    Jul 2010
    bracken ridge qld
    thanks, i had a read but not much about the noise factor. anyone had the yokohama advan v103?
    cheers
    warrick
    May 2011
    I have the v103 on my R32
    Done 15k inc happy laps x2 on them still look brand even though the wear rating isn't as high as the others.
    Haven't had good years... better than stock continentals I think, but I got the car used so tyres were a bit tired.
    But I think they have released a v105 now as successor.
    2006 .:R32 5dr Reflex Silver, Sunroof, Recaros, Tint, Flapper Mod, APR Stage 1, Sprintbooster
    Jan 2009
    Nearly all tyres with dimensions of 235/35 R19 will be quite challenged to produce a quiet ride.
    Having said that, the Yokohama Advan db decibel (V551) or the Pirelli Cinturato P1 might create less rolling noise than others.
    Jul 2009
    Bayside, Vic
    Michelin Pilot Super Sports - $349.00 at Tempe Tyres - they will ship.
    I am running them in 245/3519 and 275/30/19 on AMG C63. Got a great try out in the wet yesterday - sensational.
    I have bought from Tirerack but with the A$ down and the import charges when you hit the magic $1,000.00, the cost from Tempe was as good or better. Lots of other choices at Tempe if the PSS are not for you.
    Mar 2014
    Croydon, Victoria
    I can do Goodyear F1 Asym 2's for $270 a tyre + $80 freight to Brisbane for the set. (Or.. $1020 for a set...)
    It's coming from the official Goodyear channel too ofcourse with full warranty! So it's not parallels rubbish.
