565, even betterSooo correct me if I'm wrong but that's $665 for a genuine set ready for tyres and a mk5? This happens a bit.
There was a set of bbs rs down the road from me in perfect mk5 offsets and widths, good condition (no polishing or painting needed) all caps etc for $400, they even had tyres (wrong size though).
A redrill for $140, and a set of hub rings for $25.
Sooo correct me if I'm wrong but that's $565 for a genuine set ready for tyres and a mk5? This happens a bit.
You are correct however about the 18s, super rs in 18s can pop up cheap, but normal rs in 18 and most likely you will be bidding against buyers from world wide due to there rarity. But bbs rs reps in 18s look dodgy as, clearly the design was not meant to be stretched or scaled up like that.
Guys, I'm looking more for the CH style and want preferably a matt/satin black finish - at the moment I've got my eye on the replica's from Advance - here are the links
18 x 8 with 45ET - eBay Australia: Buy new & used fashion, electronics & home d
19 x 8 with 45ET - eBay Australia: Buy new & used fashion, electronics & home d
Both of them are very cheap and ready to bolt on - if you guys think that I can get a better deal elsewhere then please let me know.
I'm happy to pay extra for genuine but not at more than double the cost of these.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
That is cheap.
I would give them a call (they ask you to do that anyway to check on stock) - and make sure the centrebore is 57.1 which is what you'll need for your MKV. If not, ask if they can supply some hub centering rings so you can fit them up snug.
