Results 1 to 10 of 10
Thread: Best offsets for MK4s with wide wheels
    Sep 2005
    Guys,
    Im interested to know what offsets are needed for mk4 golfs, that plan to run 8inch plus rims. Is it low or high?
    Factory are mid 30s?
    Any help is appreicated! Thanks
    Aug 2007
    i have +38 on my rims and they sit flush with the guards at the front and in a bit on the back.
    Sep 2005
    How wide are your rims?
    Would a 9 inch sit too far in with +40?
    8.5" front +30?
    Or would 8" +15 front and 9" +25 rear be better?
    Thanks
    Depends on how you feel about a little poke
    This is a 9" with et18...
    This is about where mine will be sitting with a 10" wheel that is currently et52 with a 20mm adaptor (final et32)
    On the front with the 8.5 you would want a final of et30.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Sep 2006
    West Sydney
    Quote Originally Posted by 99gti View Post
    http://i69.photobucket.com/albums/i8...20mm205-45.jpg
    Good to see you were doing research before you bought the wheels Neil!
    Quote Originally Posted by rayray086 View Post
    Thanks man, I may be silly but I aint stupid! Off to see the gents at Neales wheels on Monday.
    Shouldn't be long now till they are on. Also got to sort out the 215's for the front.
    Wait till you see the streeeeeeeeetch.
    Sep 2005
    Those offsets look awsome! Im usure if redrill or adapters is the best bet. If i do some swapping around i can get a 8.5 et 30 and 9x 40 so with a 10mm spacer the 9 should sit on the guard but not poke. Whats the space like under the guards?
    Thanks and looking foward to seeing yours done!
    Quote Originally Posted by intensem1 View Post
    What diameter are the wheels? Are you looking to run a bit of stretch on the tyres? The worst is usualy the front if you have coilovers - you can get a bit of rubbing there hence 30 is about the minimum to clear them. The rears you should be fine with that, you might get a bit of rub on the outside under load.
    Sep 2006
    West Sydney
    Just went to them last week to enquire about something, they didn't have the best reception Though I know they're quite renown for wheel-related custom jobs.
    Let me know how things go with them
    Will do. I spoke to the over the phone once and I get what you mean about their recpetion lol.
