Results 1 to 10 of 17
Thread: Best bang-for-buck suspension upgrade for MKV Golf ?
    Mar 2011
    I know pretty much zero about suspension so can someone please advise the most cost effective suspension upgrade ? I’ve noticed some understeer in my MKV GTi which would be good to iron out.
    Mar 2011
    OK so perhaps I need a lesson in suspension first ? Would you start with a set of coilovers or sway bars to defeat understeer ?
    Jun 2009
    Set of coilovers and sway bars would be a great start.
    You can also get anti-lift kit's which are said to make an even more noticable difference.
    Mar 2011
    How much would I be looking at for coilovers and sway bars ? Or can you just get one or the other if on a budget ? Which would be best to get first ?
    Jun 2009
    Easiest would be coilovers.
    H&R are pretty reputable for a budget.
    anything else u would want to gain? Lowering, height adjusting?
    If neither of those last two i would say a new spring and shock combo, coilovers might be to much of a over kill.
    Maybe start with sway bars as above.
    Check out eibach, h&r, koni, kw.
    For fwd drive cars i believe the rear sway bar is a good improvement if you dont already have 1 from factory
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2008
    Cronulla, NSW
    When looking at my susp solutions, I was advised to try a great coilver setup before doing anything else. With the right gear (names as posted above plus bilsteins too) then a great setup can be dialled in and customised to you. Many times for normal driving conditions the sways won't necessarily be a big upgrade if you have great coilovers.
    However, just as many people who agree with me will also disagree and swear blind that sways are the best bang4buck you can get.
    It really does come down to how long you will keep your ride, how deep your polly pockets are, and what you want from your driving experience.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Mar 2011
    Ok thanks for all the info guys.
    I wouldn't want the car to be lowered too much or the ride comfort be compromised too much really. The main issue I have with the car is the understeer. I'm not driving around like a maniac or anything but it is noticeable. Would sway bars from APR on the rear or front be a good start ? I see they are $550 which wouldn't break the bank. Would that include fitting ?
    Jan 2008
    Rear sway bar is the cheapest and easiest - install only takes 30 mins or less, vs a few hours for coilovers or front sway bar.
    Whiteline are pretty solid sway bars, good price too - Rennenhaus have them...
    2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
    Mar 2011
    OK well I see Rennenhaus has front adjustable sway bars for $285 and the APR ones are $550. I'm thinking sway bars aren't the most sophisticated piece of equipment so can't see why there's such a big price difference ? Just due to branding perhaps ?
    Would you have to do both front and back or can you just start with fronts in a FWD car ?
