Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: BBS RS or RM help!!!
    Sep 2006
    West Sydney
    Yeah the centre hex nut looks similar to the BBS RS one... though sizing is crucial here.
    TassieGTi Guest
    I know you're probably excited and want to order as much as you can for the Cabrio rebuild, but my advice would be to have a bit of patience and wait until the wheels arrive before looking into centre caps. Then you can take a few measurements from your wheels and go from there
    I've got some BBS RS and they use a 70mm centre cap as pictured below:
    The diameter of the hole in the hex nut for the badge is 52mm. Check your wheels when they arrive
    Nov 2005
    thank you very much mate
    wabit
    Nov 2005
    "there the 70mm real bbs caps cut the tabs off and drmemeled out the remember hex till it fit, and glued them in"
    found out what i have to do to make them fit off a fellow vortexer
    wabit
