I know you're probably excited and want to order as much as you can for the Cabrio rebuild, but my advice would be to have a bit of patience and wait until the wheels arrive before looking into centre caps. Then you can take a few measurements from your wheels and go from there
I've got some BBS RS and they use a 70mm centre cap as pictured below:
The diameter of the hole in the hex nut for the badge is 52mm. Check your wheels when they arrive
