Results 1 to 5 of 5
Thread: BBS RS leak air
    BBS RS leak air
    One of my BBS RS lose about 10psi per week, so I told it to tyres shop to check it out. The guy identified the leaking are from several bolt, it needs to be separated and reseal again.
    Can this be a DIY job or better off bring it to Prof ??
    Dec 2006
    Kilsyth, VIC
    It's not so much a hard job as it is a time consuming job.
    Sep 2006
    West Sydney
    Gotta be very thorough as well. Make sure mating surfaces are squeaky clean. I usually assemble them together (torqued down) without sealant first, then run a very thick bead over the top and using your finger, push down gently so there should be no air bubbles at all. Give it a day or two to dry then run another bead over it. Works well for me.
    If you're not in a hurry to use them, I'd just DIY. Sikaflex is a good sealant for the job, just pray you won't have to disassemble them again soon.
    Nov 2005
    IMO roof and gutter sealant works perfectly, moulds into cracks, and is always flexible so air pressure pushes up against it, plus its easy to apply, and easy to clean because its clear
    here's one i prepared earlier
    Oct 2010
    Melbourne, VIC
    To get by, you could remove the bolts where the leaks are and smear sealant (Sikaflex, silicone...) around the inside of the holes at the join(s). It wouldn't stop a full on leak but yours is pretty slow.
    And make sure the bolts are properly torqued on replacement.
