I have read on other forums that some guys have issues when installing lowered springs into their MK5's due to the front springs making noises. I guess it is not a real issue but would be pretty annoying.
It is the springs (the dead coils) being loaded coil-wise and then uncoiling when the wheel is turned at very low speeds.
Is this the case with all lowered springs or just some? Seems like it would be just with the springs which are pretty low (40mm+)
