off to bed with them
and off to bath with him,long day.....
way back when the lips arrived they had been supplied raw as asked for but they had drilled them for the bolts as well....told mike as much and left them in disgust as they were pretty marked up as well.Told Mike to return them and get the blanks that we ordered but he came up to the unit one night during his offshore stint and checked them,he pronounced them 'fine' and he would get the marks out no bother. When he came back onshore he polished the lips,checked the spacing and declared them fit although one or two holes may need a slight 'tweak'.... then wrapped them up in cling film to await the centres getting returned.
Then when I went to build the huckers and silicone up the first barrel,place on the weave,silicon the top of the weave,line up dish and place on,fit the first bolt....
oh wait I cant........
EVERY HUCKING HOLE was 6.5mm and the dubious out of sync holes are a ****ing mile out although this only seems o really have been on one lip but I wish to hell I had inspected them myself more closely at the time now. So had too re-drill,fix and re-polishing the lips after machining them....
blew the table down and laid fresh microfibres
laid a bead
smear
repeat
lined up the valve just to the left off the diamond in the middle off the centre section part with the bbs info,with them being four stud that puts all the valves tdc,It also means that when you put the caps on the nuts all line up on the same side of the hex facing the valve,you either get a flat side or a point facing it
all four bolted up the same
nuts on finger tight
expensive stepping stones lol
