Results 1 to 10 of 15
Thread: BBS RS 240 custom
    BBS RS 240 custom
    Just finished these and was pretty chuffed with them,thought id share
    Been waiting on a set of 14" RS centres being returned from canada(long story,guy wanted his polished,we split a set,polished the centres,sent them over and waited on him splitting his and returning them)waited on lips coming from Image which they hucked up but we finally got all the bits back and started work. Ceramic'd the weaves as per,mike polished the barrels and faces of the lips back when they got split/delivered
    Fast forward to the other day ........... I cut them out the wrapping and gave them a once over and they were pretty marked up and/or still raw finish in areas like the complete reverse off the lip here
    following from playing with polishing and satin'd finishes on the trophies and with one of the previous fully polished sets struggling to get a solid seal on the beads I decided to satin the bead areas after id polished the reverse
    went over them with some hoch to remove handlin marks and polish remnants
    3 1/2"x14"
    couple trial shots
    getting through prepping the parts
    all set up ready to get stuck together
    off to bed with them
    and off to bath with him,long day.....
    way back when the lips arrived they had been supplied raw as asked for but they had drilled them for the bolts as well....told mike as much and left them in disgust as they were pretty marked up as well.Told Mike to return them and get the blanks that we ordered but he came up to the unit one night during his offshore stint and checked them,he pronounced them 'fine' and he would get the marks out no bother. When he came back onshore he polished the lips,checked the spacing and declared them fit although one or two holes may need a slight 'tweak'.... then wrapped them up in cling film to await the centres getting returned.
    Then when I went to build the huckers and silicone up the first barrel,place on the weave,silicon the top of the weave,line up dish and place on,fit the first bolt....
    oh wait I cant........
    EVERY HUCKING HOLE was 6.5mm and the dubious out of sync holes are a ****ing mile out although this only seems o really have been on one lip but I wish to hell I had inspected them myself more closely at the time now. So had too re-drill,fix and re-polishing the lips after machining them....
    blew the table down and laid fresh microfibres
    laid a bead
    smear
    repeat
    lined up the valve just to the left off the diamond in the middle off the centre section part with the bbs info,with them being four stud that puts all the valves tdc,It also means that when you put the caps on the nuts all line up on the same side of the hex facing the valve,you either get a flat side or a point facing it
    all four bolted up the same
    nuts on finger tight
    expensive stepping stones lol
    whoring
    left them in the office with the heater on over last night to cure,gave the bench a clear and then more microfibres and wood
    easily spinnable for applying sealing run without any risk of damage to the lips and barrels
    I guess you can just throw sealant on but a little weave ensures theres no trapped air bubbles which when rubbered up and on the car expand and can cause the seal to fail leading to a slow puncture
    finished
    and spun a few times with light pressure to spread it evenly
    zero trapped air,neat and no wiping necessary
    wasnt sure of the final specs so double checked the widths
    pretty much done and one of my favourite sets yet
    Jun 2007
    Eastern Suburbs Melbourne
    WOW.
    just WOW!
    i like volkswagens
    Jan 2010
    Springwood
    any hotter and this would need a NSFW prefix...
    WOW.
    just WOW!
    ummm what he just said!
    Nov 2009
    Blue Mountains, NSW
    So much shine, they are some proper sexy wheels. I hope you whore the crap out of them
    Audi S3-White Lightning
    Thanks for the really good comments I was really happy with how they turned out as they're the widest 14's we've done yet.These are a customers though so im just hoping they treat them good
    Holy crap sht batman, they are stunning! Wow....
