Looks awesome!!! Nice work...
i see where u coming from wabit, its just that flat/flush cap give a deeper dish look especially looking at an angle.
ray i checked your post on wheel-whores, no reply yet.
here are a few more pics for now, i'll put up some proper pics in our rides section when i take some.
1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
See if you can talk this guy into selling his caps !!
http://www.pistonheads.co.uk/sales/556071.htm
thanks Niel
hehe, i could try but i think its fair to say my chances would be low.
anyway, it shouldn't be too hard making something custom.
get some pvc pipe, thread it, make a custom flat cap & attach a badge.
How well has it held up??
Instead of making another thread, I'll ask for some opinions here - what if I were to go ahead and polish my rim lips, and then have them ceramic coated? I've seen manifolds with this treatment before and they come out very nicely with a lot of lustre, and some even look chrome-like. I know it'll be expensive but it's a small price to pay for a (relatively) maintenance-free finish. The wheels I have at the moment are two piece - centre-piece is screwed on by bolts on to the barrel which is a single piece, so coat thickness/air leakage isn't a factor (as known with clear powdercoat finishes over polished lips):
Also, when I ceramic coat something, does it have to be done to the entire object, are can it be sectioned for cost reasons? What I mean is, instead of ceramic coating the entire barrel, can I just do the outer lip section?
And also with chroming... I don't know much about these two processes, so if anyone with any experience, info or links hey can share, they'll be greatly appreciated.
maintenance isn't as bad as i thought, i've switched to mothers polish, it takes a lot less effort/time to buff out and the shine lasts for a couple of weeks. haven't heard much about ceramic coating. reason i didn't coat mine is due to cracking of clear coat around the bolts.
is that a hub centric ring in there? it looks machined to fit onto a spacer.
Yep it is. It was previously on an Audi and I quickly gave it a measure and it's at ~57mm. It's locked into place as well.
i thought i'll keep this all under one thread just haven't figured out how to change the thread title yet. Anyway, i've gone ahead and tried to referb these wheels without spliting them due to being unable to find a 10-point socket locally and the price getting them from germany. I only tried this as as there is hardly any cracking around the bolts and the clear coat is mainly damaged on the lip as you can see in this pic (that's not dirt btw).
I masked the centre section of the wheel to protect the paint from the paint stripper that goes on the lip. I just made sure the masking is perfect around the lip and i laid double layers of tape there to be sure the paint stripper doesn't get through, I also masked the rest of the centre section to protect the paint in case any paint stripper flicks as i'm applying it.
I sanded them with 800, 1000, 1200 and 1500 paper and only gave them one polish. As the bolts are still on the lip they can only be sanded down to the edge of the surface where the bolts are. They are nowhere near finished but here is how they look like atm.
They look brilliant, one of my favourite all time wheel aswellSuit the MK4s perfectly!
Whoa, I would've been driven crazy sanding in between the bolts. Looks like you did a good job of it in the pic though, well done.
