Looking good mate, what size are they.
I'm half way through refurbing mine, polishing the outer lips by hand takes a while, i'm using 600, 1200 then 2000 grit wet and dry then buffing the hell out of them with Mothers and then Meguiars Aluminium polish.
When i had them on the car before, i used to polish every 2 weeks with Mothers, then put a good coat of Mer Wheel wax on them, it worked fine.
After neglcting them and driving alot of miles down country roads near Byron Bay every day for 10 months and the brake dust got right into the perimeter bolts though......
What did you do to the centres ?? Did you acid dip or sand blast?? Powder coat or 2 Pac and clear coat ??
Matt
- You may not post replies
- You may not edit your posts
Forum Rules
